Zinfer
Who repairs Cinematronics monitors?
Both R213 and R217 are on the Horizontal circuit. R213 connects to the emitter of Q202 if 213 burned, you probably should check Q202 for also being shorted and possibly Q201 and Q203.
Did you replace the two diodes at D205 and D206?
I don't think a bad DAC would cause this sort of issue, you can swap them around and test.
