I've been wanting to add a spinner to my 60-in-1 for a while and have finally bought an old (but assumed working) arkanoid spinner.
The only posts I can find on this are from 2008/09 so was wondering (hoping, actually) that someone would have found a way to get this spinner working on the 60-in-1.
My PCB is the one with extra connections (CON3, CON4, CON5, CON6) if that helps.
I've tried setting the dip switches to be 1P Upright Cabinet, and connected yellow/green to P2 up/down on the jamma connector but nothing...
If the optic board needs to be swapped out for the Happ Active Optic board, does someone know where I can buy one of these? Or if the spinner can be made to work by using one of the other connectors etc, please let me know.
Also, if there's a way to test a spinner without needing another board (I don't have one, and don't want to buy an Arkanoid PCB just to test the spinner) — I'm looking forward to getting past the first screen of Arkanoid without getting a <B> block, which is about the only way I can do it currently, using a joystick.
Thanks!
Thanks!
