Arkanoid side art
There was some different side art used, but the Romstar was the most common. One of mine has it. It's blue with a bunch of ROMSTAR words all over it.
I used my own...
Not to highjack the thread but what kind of tool do you use to get the spinner off the top of the control panel? I've had an Arkanoid CPO I've wanted to use for years. There's a tiny little hole on the side that you put something into to get the spinner off. Any ideas here?
A very tiny allen wrench .. those (typically) L-shaped hexagon shaped profile wrenches they usually throw in with put together furniture/etc..
However, here you will need a very tiny one, in the neighborhood of 1 or 2 mm IIRC.
But in many cases, you dont need to do that, you can take the whole shaft out and that usually us installed via a screw to a gear and then a E-clip; depending on the manufacturer/style of the spinner.
This. Disassemble the spinner from the bottom. I've never messed with that little set screw.
where can I find this artwork for arkanoid? THe CPO that spyridon posted above...
