arkanoid revenge of doh
Revenge of Doh is Jamma, the original Arkanoid is not.
You can get a Jamma > Arkanoid adapter, Revenge of Doh uses 2 buttons though versus 1 for Arkanoid I think.
Doh only uses one button, the same as Arkanoid.
If your cab is wired for Jamma and has an Arkanoid to Jamma adaptor then you can plug the Doh board into the cab and it should play fine. If your cab is wired for Arkanoid then you will need an Arkanoid to Doh adaptor. I am actually in the process of building one of these for someone else right now.
I am interested in this also. I have an Arkanoid countertop, and would like to run my Jamma Doh board in it.
How much do you charge to make an adapter?
-- Bruce
