Ok, I have reached the point where I'm getting frustrated and its time to ask for help. I bought a non-bootleg arkanoid pcb a while back, put it in storage, now I'm finally getting around to setting it up. Put the wiring harness in the cab, powered it up and game runs well enough to tease me, but won't coin up.
I removed the wiring from the coin mech, and crossed "coin switch" wire (parts side 8) with ground wire (parts side 1) with no coin up. Took the multimeter to those two wires, and got 4.86V. At the board's power harness (H), I got 4.88V and 12.10V. The wiring harness does not have wires at the edge 11 (service switch and tilt switch). I read through the following threads without any luck:
http://forums.arcade-museum.com/showthread.php?t=287750
http://forums.arcade-museum.com/showthread.php?t=150975
So, I have continuity between part side edge 8 and pin 17 on the red PC030CM. I redid the solder for the PC030CM. None of the legs appear to broken.
Any thoughts on what to do next? Am I overlooking anything obvious? Thanks in advance
