Area51/Max Force resetting.. overheating?
pun84
New Jersey
I've got this Area51/Max Force.. and sometimes it'll constantly reset.. other times it will say "watchdog ... three strikes and your out" and other times it will freeze to a white screen.
Are these boards supposed to have heat sinks/fans, because mine doesn't have any. I seem to have all the proper voltages going to it, so the only thing I can think of is heat..
Anyone else have problems with this board?
thanks
I always found them to have power problems... IIRC there's an LED for low voltage and high voltage... I'd usually have to keep them at high voltage (~5.2V at the board). The other thing is the hard drives that fail of course.
DogP
AH, I was setting it so it wouldn't display either low or high. Ill try setting it to a bit higher.
Where on the board do you measure the voltages? Just off the JAMMA connector or the HDD?
I had an Area 51 that kept going into watchdog when it was in attract mode.
I replaced the HD when I added the Max Force kit and now it is fine.
Both the hi and low voltages are good.
I traced it to the addon riser board...
I would press down on one of the IC's or connector and the game would start working.
Tried to re-solder some of the connectors.. but I think I made it worse/toasted it as now the HD wont power up when connected to the gameboard! I guess my soldering iron isn't ESD protected.
Based on your recent posts about the monitor on this game getting flaky, I'd say your flyback is beginning to die. The voltage spikes caused by a failing flyback transformer caused my Mortal Kombat cab to reboot constantly too. I didn't realize what the problem was until the flyback finally gave out. It was only then that I realized that the 2 issues were related.
