Area 51 / Max Force Guns not tracking
If the Z back PS is original it's most likely worn out. Most of these cabs had the original PS bypasses with a switcher years ago which would make it tough to use the KI PS if that's the case.
Sorry for the confusion, but I have tried the KI power supply with the new harness in the z back. I have also tried a different power supply (same type as the original z back style p/s), with the original z back harness and the new slaved in jamma harness. The KI power supply is a switcher. The z back has the original style, which I swapped out with a spare of the same type to see if that made a difference.
I have not swapped out any of the a/c items, how does that affect the guns tracking? -asking because I truly don't know.
A/C noise/interference can cause problems on the video signal.
None of the video wires or circuits are shielded.
I wouldn't normally suggest this, but since you tested the monitor with the other cab's A/C power, few choices (other than wiring) are left.
Havent messed with the a/c parts yet, but since it was a quick swap, I moved the spare jamma harness video output to the KI monitor with the KI switcher and the spare jamma harness works on the KI cabinet. At least I can rule out the jamma harness.
