72Demon
Hoping someone knows what is causing this:
I am trying to add a Area 51 / Maximum Force PCB to my Z-Back Cab. It has a 25" K7000 WG monitor. The problem is the guns are not registering on screen. The triggers work, it sounds like when you are reloading, firing off screen, the screen flashes when you pull the trigger. On the gun calibration screen the crosshairs do NOT show up. I tried the pcb and guns in two other cabs and they work. I just cannot figure out why it wont in this z back cab. I tried another cab that has the same type K7000 monitor and it works too. I tried adjusting the voltages slightly up and down. I tried the brightness of the monitor. I orginally planned on using a 4 in 1 jamma switcher from RiddleTv, I thought maybe that was the differnece, and then plugged the pcb directly into the cab's jamma connector and it still does not register the guns aim. I can't figure out what else to check. Could it be wired up differently for the player 1 and 2 inputs? Does that even matter for a gun game?
Any suggestions on what to try next would be appreciated!!!!
