dukesilverfan
I found an old thread with a similar problem, but didn't want to resurrect a 7 year old conversation:
Here is my issue I am trying to figure out:
I was testing some equipment on an Area 51/Max Force dual stack pcb, and 3 "working" Happ lightguns all fail to track in a Midway cab with a K7000 in it. It's basically the exact same situation as listed in the thread above. The guns were opened, cleaned, tested, and should be working, but they refuse to track in this cabinet.
I believe the factory monitor for Area 51 is a Hantrex Polo, so I was curious if perhaps the monitor voltage jumpers on the game pcb need to be adjusted when switching to a K7000? Any experience here?
Area 51 / Max Force Guns not tracking
Hoping someone knows what is causing this: I am trying to add a Area 51 / Maximum Force PCB to my Z-Back Cab. It has a 25" K7000 WG monitor. The problem is the guns are not registering on screen. The triggers work, it sounds like when you are reloading, firing off screen, the screen flashes...
forums.arcade-museum.com
