Bullwinkle
I'm a bit confused (probably because I have a datasheet for the H1812, but can't find one for the H1809). The manual for the v2000 shows H1809, can't figure out what the G05 manual recommends as it only shows their part number. The datasheet I have on the H1812 is the one titled "Electrohome G05 HV Diode Datasheet" so can I assume that H1812 is the correct one for the G05-802?
I've seen in previous posts that DarrinF has used H1809s in both G05-802s and v2000s with no issues... thus the title of this thread. Reason being, I'm simply trying determine if I can use a replacement hv diode that I picked up locally. It's a direct replacement for the H1812, I've used it in the past though it's a much larger diode physically, it works as a replacement.. just wondering if I can use that to replace the 1809 currently in my blooming v2000.
Thanks in advance. Also, if anyone knows where I can get a spec sheet on the H1809, that would be much appreciated too.
