ArcadeVGA + JPAC!
Ambiient
Indiana
After hours of messing with Sync cables and the chassis... I got this to actually look OKAY.. But now I have one problem that I can not fix. My screen is shifted a bit to the right. like an inch or two.. And I don't know how to move it back left. I have a WG7000 (i think) Would it be the H-hold? I tried to tinker with it but it makes everything go out of wack it seems. Now mind you when this monitor is hooked up to a normal jamma board my screen looks perfect.
The picture is attached
You might have better luck over at BYAC but I'd guess it's not a monitor issue. More likely settings or drivers on your ArcadeVGA card. Ultimarc also has very good tech support so you can always go back over there and ask them or ask in the user forum.
Have you loaded all the drivers or is that just an "out of the box" installation?
Another option is to do what my father-in-law would do and just put a long piece of black tape along that strip on the left side to cover it up and hope nobody notices. :)
Yeah the drivers seem to be fine. It is just this black bar that doesn't move pretty much. Which also cuts off some of the right side of the screen for the 2nd player.
Well looks like I fixed things by just downloading Arcade Perfect Utility from the website.. And then used the pos move buttons to shift the screen. Works fine.. even though I might have to do it everytime. Not sure yet. Thanks for your help :D
If its shifting it in software thats not ideal
The control is h-pos or something, h-hold is different (sync)
Check the remote board if you have one
Hook up a jamma board and center it, then you'll know if the software/arcadevga or just the monitor
Just my 2 cents. It seems as if the K7000 doesn't sit well with anything other than an official arcade hardware. I had all sorts of problems with it on my brothers cab and my cab. I got rid of mine and I have no more worries.
