Arcadeshop Williams Panel
muchuckwagon
Columbus, Ohio
I have a blank Williams panel for a Moon Patrol cabinet. If you own one, did you put wood supports under the metal? Does the control panel need a wood spacer between the hinge and control panel for the panel to sit at the proper height in the cabinet?
Please feel free to share pictures of your panel if you have one installed! Thanks.
I had one (no longer do) but did not put wood under it. Buttons and attach nicely to it without the spacer as long as you use buttons for metal panels same for joysticks. You will have to use a spacer of some sort (wood) to get the panel clamps aligned.
