arcade monitors
You might be able to use the tubes if you already have arcade monitor boards. As far as directly using a TV in an arcade game, no. Laser Disc games like Dragon's Lair, Space Ace, ect have NTSC output from the laser disc player, so you might be able to use one there but not in a regular machine. Most games use RGB signals, so not directly compatible. There are RGB to NTSC converters but it may not be worth the money/messing around.
