Arcade monitor noise or static???/
rabidewok
League City, Texas
Please help me identify what wrong. There is noise or static on my arcade monitor??? I think it is grounded really good.. What do you thin is the problem???
What chassis is it??
has it been capped???
does it have the ground pin in the plug????
are all the grounds hooked to the monitor frame and have continuity back to the power supply or where they all connect together?????
need info or we cannot help.
Peace
Buffett
What cabinet are you using? I saw a similar problem when I hooked up a switcher directly to a pacman power supply. I'm guessing that the power supply needs to be rebuilt. I just ran a cable directly to power since it was a PC style power supply. Maybe that's your problem?
