ManiN
Has anyone else bought the matching set of locks from Bob Roberts? I bought some and found I could only install it in one position which seemed backwards to lock the coin controls type door closed leaving the key hole horizontal and having to crank it counter clock wise to get the latch in place (sweeping up from below with the cam).
I'd like to have the lock close in the vertical position (looks better) and cam sweep down to latch, but after fiddling with it for a while I gave up. The only thing I saw I could do is maybe rotate the cylinder 90deg as there are small releifs cut to maybe allow this, but I'm still afraid it will mar the hole a little bit.
Pulling the cartridge and flopping that didn't seem to change it. I also didn't notice any ways to adjust it inside either.
Any other folks have experiance here?
Thanks!
Thanks!
