cbass
Arcade games, kiddie coin-op rides, freezers and more Stockton CA NOR-CAL 95206
Once again the owner wants to sell a bunch of stuff we dont need anymore or is just taking up space.
--Mercs $200 *SOLD*
Looks good, may need a good cleaning but other than that everything works...Side are is nice on both sides, audio and lights appear to work along with all buttons and joysticks
--Outrunners Twin cab $100 *SOLD*
Both sides need monitors, owner pulled both out but everything works and is present, just had a minor grounding issue with the steering wheels but they work now...both feedbacks work, subwoofers are fine but the speakers on the headrest need to be replaced. Both are in link play
--Space shuttle kiddie ride $100 *SOLD*
Apparently a motor to make the ride start is burned out...owner replaced it worked fine for a month and same issue happen again. music and ride was smooth...needs a good cleaning
--Thunder Horse kiddie ride $350 *SOLD*
Works but the wheel slips from the arm that makes the horse move causing it to slam a little hard going down but maybe welding it should solve the issue...speakers is ripped but music box works.
--Gum ball machine $100 *SOLD*
Works but one of the gears that makes on section move cracked in half and now the gumballs get stuck there but everything else works...i was going to try and super glue the gear back together but no good. A new one should do the trick but i dont know where to get one...comes with all keys n locks, all lights work and music aswell
--Lucky egg machine $80 *SOLD*
Previous owner drilled a hole in the back to get eggs inside since he lost the keys, dont know why but that what i see...lights, speakers and rotating chicken works fine...just needs new plastic eggs and your good...also needs some new t molding
--Ice cream freezer with 2 sliding window doors $150 *SOLD*
works, dirty on the outside but can be cleaned...may need to peel stickers but its up to new owner
--Commercial Ice Cream freezer, lift top $40
works, dirty with graffiti but works. needs a wash inside and its also on a homemade roller so its easy to move around but can be removed.
--Coin operated tornado Foosball table $500 *SOLD*
Was purchased from valley gaming new, used for about 4-5 years, comes with some extra figures and some paperwork. Has a black marble finish.
--Commercial Ice Cream freezer with sliding windows $80
work, just needs some cleaning...has a knob on the side to control the freezing level
--Midway cabinet with a 4 slot neo geo $300 *SOLD*
works, has kof 94, 96, fatal fury 2, metal slug 5...sharp monitor with lock bar
--Golden Tee 2002 fore $150 *SOLD*
works, k7400 monitor, bill accepter, card data slot, green pcb, dirty but nothing that cant be cleaned
--Suzuka 8 hour 2 $50 *SOLD*
1st player side works great but 2nd player side has some issues with the pot, only leans to one side even when its completely the opposite way.
--Beatmania III 7th mix $500
Has everything inside, passes all the test just fine but then does not boot game and i can only enter test mode. Has marquee
--Xmen vs Street Fighter $200 *SOLD*
works but monitor is currently vertical but will be rotated back to horizontal, new control panel overlay, glass bezel will be included, nice picture and working coin, sound
--Mercs $200 *SOLD*
