Arcade button die cutting tool?
Madaracs
Golden Valley, Minnesota
Does anyone have an idea for what I could use for a die cutting tool for arcade button holes in a CPO?
Has anyone made such a thing? Thought maybe someone would have for say... aftermarket Multicade CPOs or other conversion/restoration projects.
Using an Exacto knife doesn't seem like the easiest task...
Exacto IS the best tool. You don't cut the holes out til after the CPO is applied. You use the CP holes as a guide/fence.
1 1/8th greenlee is what i think you are looking for cuts button holes in metal cp's
That's what I did, too.
I use a reamming(sp?) tool i have for making holes in RC car bodies. It gets the hole started, then i can clean it up with an xacto blade.
