kjoel
Found some more board sets: Shipping is additional. I will give FREE shipping if u spend over $200
- ms pacman + 1 pacman board, may be missing a sync bus controller or other smaller board/ boards. I looked at them and one of them need resoldering on the diodes/ resistor by the edge connector. One of them did work not too long ago.
- playchoice 10 board- 10 slot, looks clean. I owned a single monitor cab and it used 2 connectors on the pcb and this has only 1 edge connector so I had no way to test. this will either fit a bartop or dual monitor unit, not sure which one -
- MK2- top and bottom boards only - did nothing when plugged in
- NBA jam with sound board- bad cpu when tested
- pole position cpu board- states good one one end and bad on the other, who know if it works- it may or may not
- tekken 3- works well
- lady bug- has one ram is bad but works with character issue
- Dynamite duke- works well
- street fight- works well
- arkanoid board- untested
$265 plus $35 shipping if u take the whole lot of boards.
