Rattanee
I need to make room in my workshop for new acquisitions and I've stockpiled way too many spares, so I'm selling a -lot- of stuff. Since these need to go, if you don't like the price, YOU ARE FREE TO MAKE AN OFFER, worst that could happen is I say no.
Seriously guys, make your offers!
Bulk orders will get discounts and possibly even free shipping.
Come on people these NEED TO GO!
ARCADE PCBS:
PUZZLE BOBBLE 3 - 100% $90
ZERO WING - 100%,two player simultaneous play version! $90
VIRTUA STRIKER 2 - Mod 3 Step 1.5 fully working, can include PCB cage although it'll probably be heavy to ship. $150 takes it.
PUNISHER - bootleg, works $40
DIG-DUG bootleg (Zig-zag) - Non-jamma, works, $30
ASTERIX - Plays, has some graphics glitches, looks to be a ROM failure, self diagnostic passes though. Have resoldered all surface mount chips when I bought it (Bought it completely dead, caught in a reset loop) so the error is not a problem with the SMD components! $30 takes it
CADILLACS & DINOSAURS Turbo 2000 - Bootleg, overlay graphics glitching and jumping about, should be a fairly easy fix, missing sound amp. $15
SUNSET RIDERS - Bootleg, graphics glitches, plays blind Problem is probably the PLCC socket/chip legs are tarnished, previous 'repairman' put solder onto the chip legs, needs a little patience, should be fine, no time to toy with it right now. $15
WONDERBOY III Monster lair - Bootleg, works fine, has a "jamma" biscuit soldered on that isn't exactly jamma, so it will need a new converter. $40
EXPRESS RAIDER - DE original, fully working, clean - $40
NAMCO 246 /w TEKKEN 4 - Missing cover and drive fixing plate, works but drive is old, as with most Tekken 4s, it's hard to get booting. Includes I/O, dongle, original disc, missing VGA jumper cable, all else is there. - $130
STREET FIGHTER II Magic Delta Turbo bootleg - Colour errors but works fine, ram banking error, two rams don't get the enable signals, should be an easy fix for those in the know-how, I don't have the time for it. It's also missing a crystal in the audio section. $10
VIRTUA Striker 2 - Sega Model 3 step 2.0, missing I/O shield and PCB cage, otherwise complete. Tested with a step 1 I/O shield, just flashes an error code on the leds in cycles, rom board is most likely working. $40
Naomi Motherboard - Comes up with error 03 regardless of having a cart installed or no, comes with no I/O shield or casing. Will also throw in a second board with a short in the 5v bus - $30
CALIFORNIA SPEED - Original Seattle boards, no boot, have three of these $20 each or $50 for all three
SEATTLE networking boards, have two, both are working pulls, ($15 each or $25 for the pair.)
NAOMI Ninja Assault Namco lightgun I/O board, no wiring - $40
$100 takes the Box of surprise, a large assortment of arcade PCBs in various states of dismay, has some rare older rams that you'd pay $5 a piece if you needed to buy them now, bootleg qix and pacman, various older and newer bootlegs and originals in there (MK3, Naomi mobo, etc) . Over 20 PCBs, if you love to tinker, there are boards in there I planned to revive but just don't have the time anymore. Shipping overseas will probably be costly on this last item. PENDING
PINBALL SECTION BELOW:
PCBs:
DISCLAIMER: Unles indicated otherwise, -no- roms are included and MPU boards have -no- battery holder or battery installed as they have been removed for storage. I will however mount a remote batteryholder and burn roms of your choice free of charge if you buy more then one MPU, or a complete boardset.
I will mount a remote battery holder for any PCB for $4, or install a backup capacitor for $10.
I will burn brand new roms for the game of your choice for any PCB for $10.
(For technical reasons no 2732 roms at this time)
Bally -35 MPU - fully refurbished, light acid damage repaired, bad sockets replaced $100
Bally -35 6802 MPU - factory condition, no acid damage at all, original battery still holding charge! $180
Data East rev 3 MPU - No acid, fully working when pulled, $160
Williams System 11B MPU - No acid, fully working. virtually flawless. $160 (Have three of these) (one PENDING)
Williams System 11A MPU - PRISTINE even has original battery holder intact with no acid at all! $200
Williams System 11 Powersupply - flawless $50 (Have four of these)
Williams System 11 Powersupply VER2 - Flawless $50 (The later version with a short heatsink)
Williams System 11b aux power board - flawless $50
Williams Flipper power board - flawless $10 (Have two)
Williams System 11 Sound board (Pin Bot) - Flawless $50
Williams System 11 Sound board (F-14) - Flawless $50
Williams System 11 Sound board (Swords of Fury) - Flawless $50
Williams System 11 Display board (2x numeric, 2x alpha version) - no glasses, working $25 (Have three, plus one for F-14 TOMCAT)
Williams System 7 Sound board+ speech board - Flaweless $50
Williams System 7 display controller faulty, two are missing chips - have three, $15 for all three
Bally lamp driver - flawless $20 (PENDING)
Bally powersupplies - flawless $40, have multiple versions, inquire
Williams System 11A -complete- boardset - $350 INCL shipping!
Includes: above mentioned pristine MPU, Pin-Bot Sound board, Powersupply (No burnt connectors), Flipper power board, display board without glasses, all working, remote batteryholder, roms of your choice
Williams System 11B - complete- boardset - $360 INCL shipping!
Includes: Flawless System11B MPU, Swrods of fury type Sound board, Aux power driver board, Powersupply (Version of your choice, No burnt connectors), Interconnect board (No burnt connectors), display board without glasses, remote batteryholder, roms of your choice
DISPLAYS:
Bally 6digit display /w flawless glass $25 or $100 for a set
Bally 6digit display /w burnt glass (Working but has some malformed segments) $15
Bally 7digit display without glass, might need work, untested, $5 each
Stern 6digit display /w glass, didn't work properly, but might have been wiring, glass should be okay $20
Stern 7digit display boards (No glass) $30 a set
Boards are in collectors condition, meaning they are completely clean, washed in an ultrasonic bath, they basically look new with no hackjobs of any sort. (Exceptions are acid damaged boards, which while cleaned in the same method and are neutralized, will always show the remnants of acid damage.)
GAME SPECIFIC PARTS:
Semi-complete Stern Iron Maiden plastics set: $50
Semi-complete Pin-bot plastics set: $30
Semi-complete Goldball plastics set: $30
Semi-complete Firepower II plastics set: $20
Pin-bot blue ramp: $20
F-14 dome-set comes from early production game: $30
FACTORY prototype F-14 roms (meaning original Williams labels) $20
F-14 dome-light assy, motor and belts included, no bulbs $40
WWF Royal Rumble apron - flawless $15
Bally Beat the Clock apron - needs cleaning $15
Bally Bobby Orr's Powerplay apron - very nice $20
Gottlieb sys80b apron - very nice, has European operator's plastic moulded logo attached $10
Stern Iron Maiden playfield - VG condition, has two minor flaws, one small wearspot in upper playfield, not noticable unless pointed out, and truss rod wore through the playfield, common problem, can be repaired professionally with little work. Mylar has already been removed, almost fully prepped for restoration work. $200 as-is, or $450 refurbished and clearcoated.
There are Wiring looms available for the following games at $20 each:
Pin-Bot
F-14 TOMCAT
Royal Rumble
Bally solidstate games
Also have transformers and misc cabinet parts, along with generic and game-specific playfield machinery. I'm doing inventory right now, will have a complete list of items for sale in a PDF in a few days.
Make your offers, willing to trade for arcade PCBs and will take dead pcbs (Arcade and pinball) for a discount.
Also, I am looking for CPS 1 boards, not complete sets, but separate a, b, c boards and q sound boards to repair some games I have, so if you have any, I'd be glad to incorporate them into a deal.
Also looking for Revenge from Mars parts! Specifically: Apron, small plastic to the right of middle targets, flipper/action button switch sets both left and right, translite (no reprints, only NOS), Monitor mounting frame+cold cathode light assy, promo plastics.
Shipping: Generally the price for one PCB's shipping is $30, registered priority mail, with tracking. This is for items up to 1.5 Kilograms. The next bracket is $35 and 2 kilograms, then up to 3 kilograms as package, $80. From now on all items are shipped as trackable priority air mail, purchases that qualify for free shipping get upgraded to EMS free of charge. Buxyers will recieve a scan of receipt along with tracking number upon shipment.
ATTENTION:
Orders over $350 get free shipping (Valid for PCBs only, or items that are not considered oversize or overweight! Ex: playfields, large parts don't qualify).
ARCADE PCBS:
PCBs:
DISPLAYS:
Pin-Bot
F-14 TOMCAT
Royal Rumble
ATTENTION:
