KenLayton
In Memoriam
Two common cabinet related fixes:
The plastic "tips" of the hinges break off allowing the front tip down panel to flop all over the place. To fix it just drill a small starter hole like 3/32" diameter and screw in a 1" long sheet metal or drywall screw. See the picture (sorry it's a little blurry).
The retainers holding the clear plexiglass cover for the monitor break off allowing it to flop all over the place. Drill a 3/32" hole all the way through the black plastic front panel. Then run a # 6 by 1/2" long sheet metal screw in there from the inside. See the picture.
