Arachnid Super 6 Plus II dart board
guidoMN
Hello,
Was hoping someone might know what might be wrong with my dart board. It was working fine. I moved it to the other side of the room, about 12 feet.
Now the outer ring (doubles) on the left side (20 - 19 going left) do not register. Every other segment works.
It is an Arachnid Super 6 Plus II dart board. I reseated all the connections and resoldered the connectors on the boards going to the grid but it did not help.
Thanks for any help.
Check the plug at the end of the tail of the matrix, sometimes it can kinda split a part can can be snapped back together. If thats not it considering everything else youve already tried you possibly have a bad matrix or bad component on main board. Usually when the matrix goes bad it will kinda follow a pattern with multiple segments out.
The ribbon cable does look like it has pulled apart. I will test continuity soon. Thanks for the advice.
