jimmyfloyd
I am having an issue with my Arachnid Galaxy Smart Target PCB.
This is setup on my bench with minimal connections so that it will run. I do not have a factory cable for between them, but I have a home-built 6C RJ11 cable that is straight through. I get no light on the LED on the PCB.
Can someone with a Galaxy 1 check to see if the connector cable is straight through (ie look at the wire colors entering each side of the connector)?
Does anyone have the wiring for the connectors?
What other tests can I do to figure out why it isn't working?
