joeycuda
Let's say I build a new cabinet panel out of 3/4" furniture grade plywood and I want to apply the black adhesive vinyl that ThisOldGame sells.
The plywood is sanded, as you get it, but I'm not sure how well the vinyl will stick to the bare wood.
So..I have an entire panel that I sprayed black, as the exposed edge needs to be black. After painting, the grain is raised a bit. How slick do I need to get the wood before applying the vinyl? I want to do it by the book, whatever works best. Thanks...
