retroACTIVE
APB Seat - Folks Who Bought a Kit from DPtwiz - Please Read!
A while back I drew up some plans for the APB seat ... unfortunately I had an error in my plans...
What this means... Unfortunately for those of you who picked up a kit from DPtwiz you will find the top panel (largest piece) is about 1" too long (along its shortest side). If you measure it is 10" where it should be 9"
For the seat to be accurate and fit properly the top panel will need to be trimmed along the edge with the 45 degree cut. You will notice that the 4 holes for the bolts are not exactly in the center of the seat. The side that needs to be trimmed is the one that is furthest from the mounting holes.
I've corrected the plans for the Top Panel and they can be found here...
http://forums.arcade-museum.com/showthread.php?t=106366&page=8
I feel terrible about this and am truly sorry for the inconvenience to you and DPtwiz... If you would like to correct the seat yourself that would be fine however if you do not have access to a table saw and\or you are unable to modify the panel yourself please PM either me or DPtwiz so we can work something out.
Sorry about this... sometimes I measure off of the 1" on the ruler and end up adding 1" to the measurement... I can assure you however everything else is fine... I have built the seat using DPtwiz's kit and it went together perfectly...
http://forums.arcade-museum.com/showthread.php?t=149851&page=6
