From all the photos I've been able to find, along with the measurements I've taken, it seems to be two 1-1/2" radius corners, rather than a single radiused end that is a continuous curve. The art definitely exhibits that as well.so they are supposed to have a flat edge (to match the art) in the front and back? Instead of a round cut .
Now I just need a medium res monitor. I'm doing the double-signal converter dance to get it to display on a standard res K7000. It looks better than the LCD it had when I got it, but it definitely would be better with the right monitor. For now I will play it and beat confessions out of those perps though!Nice you lucky cocksucker!! Make no mistake, I will find my own APB with a seat before I'm done with this journey.
I have tears in my eyes.Now I just need a medium res monitor. I'm doing the double-signal converter dance to get it to display on a standard res K7000. It looks better than the LCD it had when I got it, but it definitely would be better with the right monitor. For now I will play it and beat confessions out of those perps though!
The sooner you confess the sooner the beating ends!I have tears in my eyes.
I shouldn't probably say this, but I have 2 19" medium res monitors for mine. Haven't decided on which one I'll use quite yet though. Other one will be sold at some point. One came with the game obviously and then I picked up another APB missing parts but had the monitor.Now I just need a medium res monitor. I'm doing the double-signal converter dance to get it to display on a standard res K7000. It looks better than the LCD it had when I got it, but it definitely would be better with the right monitor. For now I will play it and beat confessions out of those perps though!
Yeah, shipping tubes is a pain. But if you ever consider letting one go, I would still try to find a way. I've been trying to badger a guy out this way into selling me one too, but so far no joy.I shouldn't probably say this, but I have 2 19" medium res monitors for mine. Haven't decided on which one I'll use quite yet though. Other one will be sold at some point. One came with the game obviously and then I picked up another APB missing parts but had the monitor.
I'm probably not going to want ship it though either.
Man, so super flipping cool. Thank you for sharing your APB restore project. APB seems to definitely have a cult following. I have heard other games adapt the Mafia title. I think we need a Media title. The APB Mafia.I finished the seat restore! After laminating, trimming and applying t-molding to the ears, and using Hi Strength 90 to glue down the rubber mat I attached everything.
The only real issue I hit was that I had painted the internal mounting bracket in the cab with the same textured paint I used on the frame and then bolted it down tight before trying to insert the seat frame. Bad move, too much friction and it scraped up the end of the seat frame. I eventually had to loosen everything up, position the seat frame under the bracket and re-tighten. Oh well.
If you paint, definitely avoid the texture coating that I did. It caused way too much friction which scraped up the shaft on insertion (yes, yes, I know….). If I was re-doing it I'd just use a semi-gloss hard finish like the Rustoleum professional. Powdercoat is probably ideal.View attachment 814326
Almost done! Holes on the bottom piece aren't drilled yet because I had to rush everything out to the welder.
Now, do I paint, or powder coat?![]()
