- Joined
- Jul 29, 2019
- Messages
- 785
- Reaction score
- 923
I filled and re-drilled the countersink holes from the Tee nuts over the last couple days — one of the tee nuts had dislodged from the wood and I really had to do a number to get the bolt out of it and remove those pieces. Also fixed some flaking with wood glue. I now need to hit the whole thing with some wood hardener, then bondo a gap on one of the vertical faces, then finally paint and install the new tee nuts and flange bolts.
I also received the rubber mat covering today. Man that stuff stinks. Going to need to set it outside for a few days to off gas. @brmorr, is there any padding or anything on the seat surface itself, or just the rubber mat right over the wood?
