Anyone repair Warlords PCBs?
Does it play 4 players?
could be simple if the edge connector needs work and there is no color... Atari often used an edge connector pin to tell the pcb its in a cocktail vs an upright (instead of a dip switch)... if thats the case with warlords, make sure that pin isn't messed up on your edge connector, because as i'm sure you know the upright is b/w...
if you didn't remember that (and have an upright) check the fuse on your color overlay :)
Just being silly reminding him that if hooked to an upright harness that its supposed to be black and white (without an overlay)
but the gist of my suggestion made sense right? if the edge connector admittedly has issues, maybe the "cocktail mode" pin isn't set right and the board is acting like its in an UR?
