Riptor
I recently restocked my qbert power supply kits and apparently ordered the wrong resistors. If you recently bought a kit check the 1.8K and make sure they are not 1.8 ohm. If you already installed the kit no problem, it will only blow a couple led's and the power supply will still function fine. Contact me and I will get the correct replacments out asap.
Im pretty sure only 3-4 of these kits went out with the wrong resistors. If you ordered off my store you should have already been contacted.
