Anyone make an instruction card for a 60 in 1 cocktail?
MtZRcade
Donor 9 years: 2011-2019
Illinois
I figure that i would have seen one, but i havent. But I was curious if there are any instruction cards out there that someone made that you could print off and place under the glass of a cocktail 60 in 1.
THanks for any help
Troy
As in Professional cards? Not that I've seen. Normally I just put the normal artwork for that cabinet on it, then show them how to use it. On the rare occasions that I've made one for a company breakroom or for the buyer to put on location, I've just typed up some simple instructions, printed them out, cut them to size, them put them under the glass (if possible)...
I could make one in a few minutes.
What if he wants it to be NON-Pac related? ;)
I'd say, match it to the underlay. If it's a DK cocktail, use DK art. If it's Galaga, redesign a Galaga underlay with the instructions on the non-Galaga side of each end...
I could do that, I was thinking of a generic card that says something like:
•Insert Coin
•Use [joystick icon] to select game
•Select Player 1 or Player 2 [button icon]
Etc.
Would you then try to charge him for the file? =)
Instruction card should go something like this, at least this card would work for about 90 percent of the 60 in 1 machines I have seen.
Insert Coin and select game.
This machine has an 8-way joystick. 38 of the games on this machine require a 4-way joystick to play. So those games will not play correctly.
All the Pac-Man games and Galaga have two versions listed, one version is supposed to be speed up and the other is supposed to be normal speed. However the installer changed no settings, so both are normal speed.
Gunsmoke requires 3 buttons to play, but you only see two on this machine, don't you?
Super Breakout, Arkanoid, Centipede and Millipede require a controller other than a joystick to play. You don't see that controller though, do you?
Don't lose heart, there is still one game you have heard of that uses an 8-way joystick that is installed on this machine. It is Gyruss, and the sound on it is bad.
