modessitt
What would happen if I had a large-neck yoke from a 25" tube and put it on a large neck 19" tube with a 19" chassis?
I have a 19" chassis to test that needs a 10-pin large-neck tube and a low impedance (2.5-ohm horizontal/13-ohm vertical) yoke. I have a yoke that is the proper impedance and size, but I think it came off of a 25" (or larger) tube. The yoke will go on okay, but has it's own standoffs rather than using the rubber wedges.
As the impedance is proper, I don't see why it wouldn't work....
