Anyone know if..
Djm
Finishing touches on ninja gaiden does anyone know if the jump button only works when by an object tested all micro switches all working but jump then tried one micro I know is working.. still nothing .. but jumped onto a pole once... Confused if it's the entire wire to the jamma harness or just that function is only at certain times
There should be 3 button inputs in total:
- attack (punches/kicks) - red button
- jump/flip - blue button
- grab overhanging poles - red button on top of the unusual joystick
in the test screen on boot up you'll see the "Grab" button in the UI shows as in the middle of the joystick
I screenshot the test screen in mame and cropped bottom left to show the p1 input here below
Green Arrows should show the joystick tests
Red circle is attack
Blue circle is jump
Lighter Red small circle in middle of joystick is that "Grab" button
I think this is the correct/original control panel layout including the unusual joysticks:
finally a snapshot of that instruction card on the bezel that explains it:
