discgolfer72
i was up at the local micro center pc store looking around for some speakers and some solder and ran across a velleman soldering station for 19$
since the weller station was 129$ i decided to pick the velleman station um (hell as long as it works a little it was worth the 19$)
anyone ever heard of them are they at least descent
this one seems sturdy and well built and it also has a grounding spot on the back for woking on senstive boards
the specs are
input voltage
110vac 60hz
temp
175c - 480c
tolerance 5%
and has a ground output
the one concern i have is the tips .they did not have any replacement ones at the store, but it looks like the standard weller pro tips should work
am i correct in thinking that can you tell by this pic
the specs are
input voltage
110vac 60hz
temp
175c - 480c
tolerance 5%
