Cheap means intermittent results.
I bought my nice one for about $40 brand new...
Twisted Quarter has one for $44: http://www.twistedquarter.com/index.php?main_page=product_info&cPath=71&products_id=473
ken
I bought mine at Fry's for $3995. No shipping as I could walk right in...
http://www.frys.com/product/487898?site=sr:SEARCH:MAIN_RSLT_PG
Mine cost me almost nil.
Take one disposed of TV (easy to find now-a-days... everyone is pitching CRT-based TVs) 19"-25" diagonal, take off the case and extract the degauss coil from it; you can cut off the connector. Also snip off the power cord. Twist the coil into a figure-eight, and continue until it is doubled onto itself. Wrap the doubled coil with electrical tape. Strip back each wire end, and connect the coil to the plug wire using wire nuts (polarity doesn't matter).
This coil will likely get warm pretty quickly, so you'll need to do your business without ado. It helps to have someone else who can plug it in when you're ready to go, and unplug when you're done. (If you want to get fancy, wire in a momentary switch for easier solo operation.)
Ditto!!! Those home made and quick fix kinds suck, just buy a real one for 40$
I disagree. I've used the soldering gun method MANY times and it's worked perfectly every single time.
Bill
I bought mine at Fry's for $39.95. No shipping as I could walk right in...
Bill
