Anyone ever put a 27" CRT in standard Cruis'n USA cab?
brandogg
I'm probably gonna pick up a couple D9400s this weekend (putting one in my Warzaid cabinet so I can hook up my Dreamcast over VGA as well as use Warzaid/Jurassic Park III over medium res), and then I was going to try to put the other in my Cruis'n USA, which has a 25" U5000. This would free up the U5000 to be able to swap into any of my other cabinets (all 25" K7000s) if I need to repair a chassis or something. Has anyone ever done this? I think there's room but not sure. I know I'd have to get different mounting brackets, and a different shroud.
I don't know for sure. Most have mounting tabs on the top and bottom, so your main fitment issue might be the width since there's no easy way to gain width. A 25" shroud might be OK, you could just size the picture down using the digital controls.
I had a similar idea with using mine in the live monitor of my VR. But there was not way it would fit in that situation. It's a tight fit even for a 25".
Also, the dims for d9200/d9400 are online so you can make some educated guesses on whether this would work.
