Anybody Know Anything About Terminator 2?
ThunderBunny
Winchester, Kentucky
I have T2 that I cannot get it into the diagnostic menu. I need to calibrate the guns and use the test patterns and colors to adjust the monitor. I have tried just hitting the service button and turning it off and using the dip switch. Am I missing something?
You probably have a ground that is missing from one of your coin slots. This ground is needed for both the service credit button and the test switch to work. I found this out last night :)
Before I got mine working I manually got into the test menu using the dip switches on the main board. From the front of the machine you need to remove the access door. There is a latch at the top of it that you need to remove by sticking your hand through the coin door. Pull the board out slowly watching for any wires that snag. Then locate DIP switch 2, and flip the #8 switch. Check the attached pics for details.
Also let me know if you need the PDF manual for it...
You are exactly right about the coin door. I have it completely out. I've tried the dipswitch and it just starts like normal. I will try just using a ground to get it with the button tonight. Thanks for the heads up there. I would've never figured it out.
