Any tips on removing joysticks from Karate Champ upright
Klassic
Boynton Beach, Florida
seems simple. but there is a cover on top of the control panel that seems stuck on. should this come loose since the joystick is unbolted from the bottom? i have a new CPO, and it's just weird the way this panel is put together. even the 1 and 2 player buttons needed a lot of tapping to pop out of the hole.
thanks.
With them unbolted are the bases still stuck to the underside of the control panel? They don't wiggle at all?
I think the hole in the control panel is large enough for the ball on the stick to pass through,s so you shouldn't have to take the stick apart.
I think what you are calling dust plates are actually a non moving part of the base- those look like coin control sticks.
Feel free to take more pictures of where things stand at the moment.
got it, thanks. someone used epoxy on the underside, so took some brute force. joystick and all fits right thru the hole. thanks...
