VectoRaster
My Centipede mini wouldn't start after 2 months so I thought: no problem - just need to recharge the battery. Plugged it in and after 5 minutes smelled something burning. Took it apart and found the problem. One (or both) of the capacitors coming in on the tackball controller card's 5v power line is shorted. The game won't run with the controller card plugged in, but works when disconnected (of course without any control movement). My Li-ion battery doesn't hold a charge anymore, which I guess makes sense due to the voltage demand created by the short.
Hopefully this is on-topic enough for someone familiar with the design of this type of controller interface to know what I need to do to repair it. The 5v trace has continuity all the way to the connector. If you were in my situation, what would you do?
I have no idea what capacitors I need since there are no wiring diagrams or schematics floating around that I can find, but maybe someone out there with a lot more board repair experience than I knows . . .
