daddyboo
Hey Guys,
I'm trying to replace a motor on a sea devil that connects to a chain sprocket, and as I was trying to pull the old motor apart from the chain sprocket that it connects to, I came across a bolt or screw that I'm not familiar with. It runs all the way through the outer axle through the motor axle of the new motor that I'm trying to replace. I can't tell if this connector is threaded or just tapped through but it will not come out. Doesn't appear to use an allen wrench - it is tiny! I have a tiny allen wrench and it is even too big. I tried to puch it out with no luck but stopped because I don't want to damage it. It is flush on one end and extends out on the other (no visible threads).
Any suggestions?
Any suggestions?
