So, I tried it with the two most left ones and didn't get any reading. But when I did 3&4 it lit up the whole left column. So, it sounds like the keypad is in the clear and like you said an issue with the game board. Which sucks, I was hoping it was going to be something simple like the little circuit board being bad.That sounds like a problem on your game board, not the keypad.
Disconnect the keypad and short the left-most 2 pins in the keypad harness, and see if you get a single digit or the whole column -- that's the middle key in the top row.
Then short 3&4, which should be the bottom left key.
Wondering if maybe it's a voltage issue. The force feedback is spotty and when it tries to work it drains power to the music button light and makes it flicker. Just guessing since I have no idea where to begin looking on the game board to fix the keypad issue.That sounds like a problem on your game board, not the keypad.
