If you still need one.
Went ahead and hit it with some sandpaper and black paint, got you some screws and washers. If the slide bar is too tight add a washer underneath the bracket to shim it out a bit.
Sadly I haven't been able to come up with a wing nut for the slide bar, but the wing nuts on the power supply are the same. You can use one and go to the hardware store to match it up.
