Any idea of this TV has a usable tube?
hindered
Donor 2015
Kalamazoo, Michigan
I picked up a 19" TV at a garage sale super cheap hoping it could be salvaged for use in an arcade monitor. I know I can buy a compelte replacement chassis, but I have a few k4900s, k4600s and G07s laying around that have some pretty decent burn. Googling isn't turning up any information about this TV model and I figure I'll need to crack open the case and take a look to find out for sure. I was just hoping someone would know before I tackled it any further.
It's a Quasar WT5962SW
Chassis #: MT5977NA.04
It doesn't have a tube number listed on the outside.
You need to take the back off the set and look at the neck connector on the picture tube. It probably took you longer to post this than it would have to check for yourself :)
-Ian
there's only like 4-6 screws on the back you need to take off if that, remove them and look for the tube# or see if you can shine a light thru the vent to see it.
