I was just looking at the Klov database for Hyper Sports and noticed that there is not a section for all the bonus point tricks that you can do. I wrote this up a while ago and I was going to submit it, but I just wanted some other Hyper Sports experts to look thru and make sure I got everything. Let me know what you think
___________________________________________
Bonus Point Tricks - Each event featured opportunities for bonus points:
Swimming - If you tie the computer in the race, a frog comes up out of the water and gives you 3,000 pts.
Skeet Shooting - If you shoot every disc, the final object will be a white ghost. Shooting this white ghost with the RIGHT button will give you a 3,000 point bonus. Shooting this ghost with the LEFT button will give you a 3,000 point bonus AND will bring out a flying bird. Every time you hit the bird you are awarded 1,000 additional points. If you shoot every disc on your second attempt, the white ghost will be worth 4,000 pts... but this time, shooting the ghost with the LEFT button will give you just the 4,000 point bonus, while shooting the ghost with the RIGHT button will give you the 4,000 point bonus AND will bring out the bird for additional 1,000 point opportunities. Shooting every disc on your 3rd attempt will give you the white ghost for a 6,000 point bonus. Just like on the first attempt, shooting this white ghost with the RIGHT button will only give you the 6,000 point bonus, but shooting the ghost with the LEFT button will once again bring out the flying bird for the additional 1,000 point opportunities. Total potential bonus scores for the first round of the Skeet Shooting are: 17,200 (1st attempt), 18,200 (2nd attempt) and 20,200 (3rd attempt). Also, hitting two discs at the same time (one in the left box and one in the right box) will give you 500 points rather than the 100 points total you would get for hitting them individually. Doing this will alter the above scores (17,200, 18,200, and 20,200) slightly.
Long Horse - If you do 1/2 of a flip and land on your head an object comes down and gives you a 3,000 bonus. NOTE: This will not qualify you for that attempt so only do this if you have already qualified.
Archery - On your first attempt, if you get all bulls-eye shots (600 pts) for a total of 4,800 pts, you will receive a 3,000 point bonus. 3 apples will then come out. Each hit on the apple will give you 1,000 additional points. Doing the same on your 2nd attempt will give you a 4,000 point bonus and the 3 apples. All bulls-eye shots on your 3rd attempt will give you a 6,000 point bonus and the 3 apples.
Triple Jump - If your first jump is touching the line and you get the angles 35, 41, 45, a plane will fly across the top of the screen and give you 3,000 pts.
Weight Lifting – If you press both run buttons simultaneously when the barbell hits the ground, a bunch of cheerleaders will pop up and give you 1,000 additional pts. You can do this on your 2nd attempt for an additional 1,000 pts.
Pole Vault - If you hit the base directly with the pole (no skid across the base) and make it over, a gopher will come up out of the ground and give you 1,000 points. If you do this consecutively, the gopher will continue to give you bonus points of 2,000, 4,000, 8,000, 8,000, 8,000 etc., etc. If you miss a vault or if you don't get it directly into the back of the base, the gopher will not come out and then will start the count back over at 1,000 points the next time you get it perfect.
NOTE: If you perform these bonus point tricks on the Swimming, Tripple Jump, or Pole Vault and also achieve a World Record at the same time, you will not recieve your bonus points.
