massatari
Getting brave here. I have a K4900 with really bad burn in. I came across a donor C23 RCA A48AAB13X02, took it apart and found a bonded yoke. I grabbed readings from it and then decided to remove it. Maybe 5 minutes with a heat gun. I'm going to assume this is going to be ok to move forward with the swap. Any tips or input would be appreciated before I finish this job, or is this just business as usual at this point?
