Yes, I freely admit that I'm a noob. I am beginning to wonder if my logic probe is faulty because no matter what I probe, I do not get a blink on the pulse light. (No, it is not set on men). I even tried on the clk. So let's put that aside for a minute and break out the scope which I am also a noob with…
Keep in mind that I am running the v1.3 test rom. The Midway manual page 39 talks about the sense line getting high signal when the cowboy is on the screen. Are similar readings expected when running the test rom? Start to finish or only during the shifter test?
My scope does show virtually the same picture as that so it appears that the SAMPLE signal is correct on the daughter board.
This is inverted by F3 before entering the 7442 E3-12. According to the truth table, this will cause all of the port lines to be high
The next thing I noticed on the 7442 @E3 was that while Vcc is 5v, all of the port lines at only at 4vdc. Ports 4 and 6 are not a totally flat line, but the variation is only about 0.1v
What I really don't understand is the inconsistency…. 2 different programs running will sometimes reset very soon after booting and other times get into the attract screen or shifter test before resetting. If it is a stuck pin or bad trace or solder bridge, wouldn't we see the same behavior each time?
Is this more indicative of a bad cap or diode? Sense seems to be working, the watchdog is barking, so the counters are not getting cleared consistently, right? So what tells the watchdog timer to reset? Port 4 off E3 needs to go low to reset the 74161s at D2-1 and E2-1.
I guess I need to know exactly what the 4 inputs to the E3 are doing so that I can confirm what should be happening on the port lines.
Thanks for you patience!
