another silent scope 11-p question
Update
So I tried using the standard ss2 mame files on my innocent sweeper and it gets past the 11p error but now gets the security error, if I try the standard silent scope or silent scope ex files I go back to the 11p error. Does this sound right? This has been a long expensive ride and now the mame dump is not out there :( I need the asia dump for silent scope 2
On the security error, try holding down the test button when you power it up, either inside the coin door or on the pcb itself. Another guy on here had the whole sequence to go through...
hitech1 said:
Keep the test switch depressed and switch the machine on.
Keep the test button depressed until the screen will read, i'm not sure of the actual wording but "RTC initialized. press test button to set manually".
Release the test button and press again to go into test mode.
The settings that requires adjusting will be highlighted
Do not adjust the date and time, just accept and exit.
Do the scope and gun calibration.
After this is done game menu will appear at the bottom of the test menu list.
Go into game menu and the game should be OK.
I tried that
Thanks I tried that already no difference at all, That might work for password but I read security means wrong code on chip. funny though if I use ss1 still says hardware error but if I use ss2 it say security error, I think I need a Asia ss2 dump.
Probably, but figured that couldnt hurt, and made a good last ditch effort :)
Good luck, and if you find one, share the love w/ anyone else needing it!
BTW, did you try all 3 of them from emuparadise?
