davemcl
I have a Sanyo 20 EZV I want to use to restore a dedicated DKJR back to original, unfortunately I don't have another working one kicking around to refer to. The yellow & white wires from the yoke PCB at points EG & EH were hanging loose on the chassis PCB, I resoldered to the posts on the chassis at AM & AN. There is another wire (red) coming up from the oint labeled R232 that appears to be cut about 8" long. I don't have a clue where this goes & don't see any stray wires anywhere on the monitor. Any idea where the other end of this should be connected?
Next question
There's a connector with red & white wire coming out of the little transformer monutes on the monitor frame. does this get powered with 100V from the isolation XFMR also?
Next question
