Another Rush question
Rush the rock? Mine are running at 5.1 when I last set them, no issues (measurement taken at the hard drive connector with flash IDE card, not HD)
The safe operating range is 4.75 to 5.25 volts.
HOWEVER... With that being said, Sega NAOMI 1/2 systems should NOT be run at anything over 5.1v. At 5.2v they will start to lockup and eventually the cartridge or DIMM board will die. The bus buffer chips they use are very voltage sensitive.
