Another question...
Pengo13
New York
Can I use a 25" tube currently with a Hantarex Polo chassis with K7000 chassis/yoke?
Thanks for the help.
the tube is the same.
measure the yoke and see what the pairs are.
you should be able to reuse the yoke.
zenomorp has done this a couple times.
Peace
Buffett
Thanks for the info.
Peace
Buffett
I did this this morning. I used a polo 25 tube with a k7000a chasis. The ohms on the wells tube was 1.5 and 9.8 the ohms on the polo tube were 1.6 and 5.6. I did not change the yoke just had to snip the degaussing wire and the yoke wires to use the wells Gardner style connector. The wire colors were all different except for the brown on the yoke wires so make sure you keep them straight and not mix them up or you get magic smoke (buffet uses this term) :)
Thanks for the info. Can you post a picture of how you connected the yoke wires? That would be very helpful.
