I just replaced all bulbs, only the deal/draw button lights up after a coin is inserted
Thank you for the response, the ribbon looks good, but I can see how there could be a problem inside it. I'll check out that site. Thanks!re deal draw light
that is normal on start of a game, (ie coins are put in, )
that is only button to light up, it is waiting to be pressed, (but if non working you have the result stated)
then after its pressed, and 5 cards are dealt out, then the other lights will light up,
(but since no buttons are working, this is not happening)
you likely have connections or wiring issues somewhere, (or multiple places)
there are multiple failure points in this harness
the big ones are the 14? pin ribbon that goes into a buffer pcb, (the ribbon can be bad, the pins can break bend, the wire inside can break, or get disconnected from ribbon to pin connector, ect ( was a bad and unreliable design even when new)
then the harness where it bends around /near the coin door open close hinge area is a spot many times wires can break inside or get pinch, or have internal intermittent connection, then theres all the harness at or near the buttons, lots of slip on connectors on buttons, ect
also research this at newlifegames.com
That's my next step. I pulled out bulbs and cleaned everything, put back together. While I was testing holding, after winning a couple of hands, hit cash out, and now the hopper won't quit spewing out nickels!check each button separate for ability to go on /off via a meter
As soon as I hit the "on" switch, the switch on top of the hopper automatically engages and the nickels start comingcheck the heavy duty coin count switch on hopper for broken or out of adj
