another light gun question
Token420
Georgia
I recently picked up 2 Lethal Enforcers light guns. What tool is used to take these things apart? The bolt heads do not have slots and the nuts are recessed and are a very tight fit.
If they're anything like the HAPP guns, you'll need a security torx bit. The recessed nut is just there so the screw has something to grab onto.
If you're looking for a cheap set, Harbor Freight Tools carries them...
I have a security torx bits but the bolt heads on these guns are smooth.
Can you provide a pic? Judging from your description of the bolts, it sounds like they might need an inverted torx bit instead...
Small wire clipers or needle nose pliers are what I used last time. They're a real pain since they're so small and the pliers slip off the bolt head easily.
So that's what they're called!
Are they spanner security bolts?
